Re: Weight of a IH 460 Utility Tractor
Posted by Nat 2 on February 01, 2007 at 13:44:26 from (64.80.110.27):
In Reply to: Weight of a IH 460 Utility Tractor posted by Bob Calkins on February 01, 2007 at 12:56:15:
tractordata DOT com lists the FARMALL 460 at around 5300 pounds DRY, with no implements, wheel weights, or fluid in the tires. I would expect the Utility to be similar, but they don't list a utility that I can find.
You could easily be looking at an 8000lb load here, depending on what's on the tractor. I would plan on hauling an 8000lb tractor if I were you.
Frankly, my main concern wouldn't be the ramps... Will your trailer and truck handle the weight? If they can't, then it doesn't matter what the ramps can hold up.
