Re: Qustion on IH remote stroke control hydralic c
Posted by Brian in MO on February 02, 2007 at 11:19:20 from (69.21.75.21):
In Reply to: Re: Qustion on IH remote stroke control hydralic c posted by Randy as in Randy-IA on February 01, 2007 at 18:59:09:
Randy they can be used with any tractor, they just close a internal valve on the cylinder when the stop pushes the rod. I'm not sure about your 1755's hydraulics but most hydraulic levers will go to the "neutral" spot when the cylinder bottoms out that's really all the cylinder is doing, if yours keeps putting presure after it stops I suppose you could push the seals out of the cylinder.
