Re: 826- Placing Extra Gauges
Posted by K.B.-826 on February 02, 2007 at 17:06:15 from (71.10.83.51):
In Reply to: 826- Placing Extra Gauges posted by Jim Allen on February 02, 2007 at 05:30:38:
When the M&W turbo kits were installed, the pyro was mounted on the top of the left dash cowl. A hole was drilled in the cowl for the cable to run through, and the mounting bracket attached with three small self-tapping screws. I've often wondered if a guy could take the panel for the fuel, oil pressure, and air cleaner guages from a 66 series that mounts above the steering wheel and modify it to fit a 06/26/56. That would look pretty neat.
