Re: Ring Compressor
Posted by RD/Oh on February 02, 2007 at 17:07:05 from (65.17.134.110):
In Reply to: Ring Compressor posted by CNKS on February 02, 2007 at 12:45:29:
I have had the same problem. This was my solution and it works great. first make sure the edges of the compresser that lap over are even when tite.( I just use motor oil for lube). put the piston in the hole, make sure the compesser isseated on sleeve,use wood hammer handle and lightly tap compresser,as it may be a little off. Hold compresser down on sleeve, with the wood handle bump the piston down,when the handle hits the piston keep pressure on it don't let it bounce back. good luck let us know the outcome Ron
