Re: B headgasket question
Posted by CLIFF S on February 02, 2007 at 18:30:55 from (205.188.116.133):
In Reply to: B headgasket question posted by Charles McNelly III on February 02, 2007 at 18:15:02:
I wouldn't put a pressureised gasket on without a waterpump! I would bet it would get Hot if you run it long! I have known some As with mowers on them to get hot without the addition of a water pump, My A will Heat up enough to loose power on a Dyno and push water out if you run it under a hard load with a stock large hole gasket so i wouldn't advise it!
