Re: F-20 Rear main seal
Posted by f20inmi on April 12, 2009 at 19:34:06 from (75.167.203.133):
In Reply to: F-20 Rear main seal posted by Tiger Tex on April 12, 2009 at 18:45:51:
Get ready for a chore. The nut should come off with a set of plumbing pliers. You will need a heavy (and I mean heavy) duty puller to pull the flywheel off the shaft. It laughed at my harbor freight puller. The seal is a felt seal is straight forward swap. Rice Equip will have the seal. The big pain is putting it back together. You have to install a dowel at the same time that flywheel is slid back in place. It took 3 of us to re-install the flywheel. You will want to heat the flywheel on the bbq grill and then two of you will push the 100+ lb flywheel on the crankshaft. The third wheel will install the dowel at the same time you are pushing the flywheel on. Good luck.
