Re: Ring Compressor
Posted by Janicholson on February 03, 2007 at 07:37:04 from (66.216.226.55):
In Reply to: Ring Compressor posted by CNKS on February 02, 2007 at 12:45:29:
CNKS,
I like ROoers post, Another addition to that is to bell out the chamfer in the sleeve. There is no ring travel there, so no foul. With a lathe, a professional (one size compressor can be hatched by using an old sleeve, cutting it to about 3" including rim, then tapering the top of it at the rim then installing the piston into that compressor with tahe regular compressor. The bottom edge can be ground to fit the chamfer exactly. thus not getting wedged in a gap, and not spiraling in itself. Good luck, JimN
