Re: Farmall H differential bearing carier
Posted by Brad in WI on February 03, 2007 at 08:19:44 from (24.208.26.46):
In Reply to: Farmall H differential bearing carier posted by Guyzoo on February 03, 2007 at 07:03:55:
Are you talking about the housing that is by the brake pinion shaft. That housing I beleive is different for each side. the shaft and the bull gear is the same though from side to side
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
