Re: Purpose of a hydraulic check valve?
Posted by richard in nz on February 03, 2007 at 14:51:44 from (222.152.222.163):
In Reply to: Re: Purpose of a hydraulic check valve? posted by Janicholson on February 03, 2007 at 07:19:34:
It is pretty well the same thing, a pilot operated checkvalve, but when used for that purpose they are called a hose burst check valve and are mounted on the ram, not the valve. A hose burst check valve however will not stop a ram from retracting if the ram seals fail as oil simply is leaked from one side of the ram to the other without passing the valve.
