Posted by ScottyHOMEy on March 11, 2009 at 11:47:56 from (64.222.222.178):
In Reply to: Re: adjusting clutch posted by eric skokan on March 11, 2009 at 11:33:27:
Depends which way you're out of adjustment room. As the clutch wears, freeplay is reduced. If you can't adjust the rod to pull it any further back, i.e., the front nut is running into the non-threaded part of the rod, then, yes, I'd take it apart and start with a new friction disc at the least and evaluate the pressure plate and cover with an eye to whether they need replacing, too. If you're running the nut off the end of the rod, then there's something else going on.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
