Re: Synthetic Oil
Posted by dej(JED) on February 05, 2007 at 05:35:56 from (66.212.151.134):
In Reply to: Synthetic Oil posted by Tractor Shed Billy on February 04, 2007 at 17:21:32:
Don't use a low ash diesel oil in a gasoline engine. A gasoline engine oil needs ash for lubrication. Engine oil dillution from gasoline will destroy the low ash oil. It is made for a diesel engines only. Yes, you won't see damage right away. It take a while to wear at the bearings.
