3 pt hitch lift - push plate?
Posted by bruce omn on February 05, 2007 at 12:34:33 from (148.150.136.182):
Hello all,
I'm thinking of using my 460 regular with an aftermarket 3 pt to pull or lift some old trucks weighing from 8k to 14,000 lbs.
The 3 pt mounts only to the rear axle, so I'd like to mount that to the rear case better. I also want to tap new threads in the wobbled out hitch under the belly.
Assuming that those are successful, how much should I expect the tractor to do? I'd like to make a harness mounted on the 3 pt that will allow me to lift the lighter trucks or put weight on the tractor when I pull out the bigger ones.
Any experiences like this? Thank you
