Re: Jump Starting/Charging Connections
Posted by Janicholson on February 05, 2007 at 16:44:43 from (66.173.50.146):
In Reply to: Jump Starting/Charging Connections posted by Bud W on February 05, 2007 at 15:40:55:
The polarity must match + to + - to -, Bob is correct, I'll add the possible starter motor stuck (do the lights dim way down when trying), or open, or switch (Starter) failure. JimN
