Re: M starter
Posted by Janicholson on February 05, 2007 at 16:48:26 from (66.173.50.146):
In Reply to: M starter posted by Boyd on February 05, 2007 at 15:39:32:
Use beyond reasonable (starters should be on for 20 seconds for every two minutes off), or they get hot. Internal shorts will cause it. Dragging armature from worn end frame bearings is the most common real fault. All can be fixed on the bench with a repair manual, and common tools. JimN
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
