Re: fast hitch 3 pt conversion
Posted by Wardner on February 05, 2007 at 18:19:58 from (206.148.21.12):
In Reply to: fast hitch 3 pt conversion posted by Ronald on February 05, 2007 at 17:44:02:
The tongs come straight, bent, offset, and welded to an arched shaped bridge that connects the tongs into one piece.
Your tongs will need to be different for various applications. For instance, will you be using the PTO? Where will you attach the top link? Where will you attach the tongs on the implement?
Don't bother answering. I still couldn't tell you how to fabricate your tongs. You will have to put the tractor and implement in proximity and go from there.
The proximity thing works. I figured out how to mount all the implements for a Cub when I was eight or nine. I had no help or manuals. I just moved things around until they fit.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
