Re: w4
Posted by Janicholson on February 05, 2007 at 18:43:07 from (66.173.50.146):
In Reply to: w4 posted by jimike on February 05, 2007 at 18:08:25:
Can be done and should be done may be two different things. I cannot recommend any mismatched gears in a power transmission system. The fourth would be compromised and mot usable for loads without stressing the driven gear. If both top and Layshaft gears were replaced with H cogs, I have no issue.
Belly pump out top cover off, clutch and clutch shaft out, remove front carrier and constant mesh gear (catch bearings in a stretched cloth under the slider!! Very important!!) Remove lower shaft front bearing retainer and disassemble to replace gear (or cluster, I cannot remember if they are seperate). Reassemble. Books are important here. Both IH reprint or original repair, and IT manual from this site. JimN
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
