Re: HELP!! clutch won't disengage
Posted by Nat 2 on February 06, 2007 at 04:50:31 from (64.80.110.27):
In Reply to: HELP!! clutch won't disengage posted by klf on February 05, 2007 at 21:39:12:
Your only hope is to get the tractor into a heated building, to see if somehow moisture got into the clutch area and froze up the works. It will take several hours, perhaps days, in above-freezing temperatures to thaw everything out.
Most likely, though, the clutch just picked the worst possible time to give out on you. There's no "turn a screwdriver" fix. It'll need to be trucked off to a shop with the proper equipment to be repaired.
