Re: Removing Clutch From WD6
Posted by Nat 2 on February 06, 2007 at 05:06:01 from (64.80.110.27):
In Reply to: Removing Clutch From WD6 posted by Tyler Cohrs on February 05, 2007 at 20:06:38:
Maybe I'm wrong, but I believe you have to split the tractor to get the flywheel out. You can't replace the rear seal without removing the flywheel.
If a WD6 is anything like an M, the clutch disk and pressure plate should be removable without splitting the tractor, but the flywheel isn't.
