Re: Seed Plate Drive Oil/Seal
Posted by Daniel H. on February 06, 2007 at 17:34:13 from (66.226.34.159):
In Reply to: Seed Plate Drive Oil/Seal posted by SuperA-Tx on February 06, 2007 at 14:23:44:
The oil is final drive oil. There is a seal around the seed plate drive; on the Super A there is a "carrier" that is bolted to the final drive for the seal. Later models use a seal that presses into the final drive. The later seal will work, don't use the carrier, and the seal will ride in a different spot on the drive and "should" seal better if the drive has a groove worn it. They will also leak out the center. The 140 added a extra washer with grooves for o-rings to seal the center, but you need the bolt from the 140 too, as it is longer. The Super A will not have this, unless the seed plate drive was a later add on.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
