Re: HELP!! clutch won't disengage
Posted by RR Mech on February 06, 2007 at 20:19:59 from (12.154.7.21):
In Reply to: HELP!! clutch won't disengage posted by klf on February 05, 2007 at 21:39:12:
3388 is the smallest 2+2 I think and it has mechanical links on clutch. The problem is either the bracket on the bottom front corner of cab is broken or the throw out bearing has failed and ate the fingers off of the pressure plate. if it is the bearing and pressure plate it will have to be split of course. Good luck.
