Re: M heads
Posted by Janicholson on February 07, 2007 at 09:28:24 from (199.17.6.122):
In Reply to: M heads posted by Lee at Elk Mounds on February 07, 2007 at 08:50:25:
I think that there were no LP factory Ms. Thus there are no stock High compression heads. The high altitude *000 ft head may be higher compression than a standard gasoline head, I'm not sure. Piston top configuration may have been used to achieve more compression. The propane head from a factory 450 I'm sure, and maybe 400s would be the highest compression. JimN
