Re: differences of later and eirler models
Posted by chadd on February 07, 2007 at 10:41:20 from (155.92.31.43):
In Reply to: differences of later and eirler models posted by ole farmall on February 07, 2007 at 10:17:34:
Early M's had a larger oil filter element and canister, usually came with the dual fuel carburetor, and had a small starting tank for gasoline and a second tank for Kerosene or Distillate, the lower compression head to allow it to run the lower grade fuels, a different fuel tank support, a lower pressure belly pump, a slightly different setup for the steering shaft center bushing, a different cast front end assembly that used more cast and shorter channel pieces, non-adjustable front wheels (the adjustable were optional), a different PTO unit that did not necessarily run at 540 RPM, A different transmission fork assembly, Different seats, the shift pattern cast into the differential top cover/ platform (later ones just got a sticker), Non-pressurized radiator (later models were pressurized), different sheet metal using Dzus fasteners instead of bolts, and the electrical system of the later tractors used a regulator instead of a simple cut-out relay. Those are all of the differences I can think of off hand, I am sure there are more. Extra horsepower came from the higher compression head that became standard on the later M's. Early M's could kerosene, gasoline, or distillate. Later ones could run only gasoline unless a different fuel was specified when the tractor was purchased.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
