Re: Super-C Carborator problem
Posted by Brownie450 on February 07, 2007 at 10:51:29 from (207.177.82.83):
In Reply to: Super-C Carborator problem posted by Don's superc on February 07, 2007 at 09:10:59:
If you are going the repair route, check the condition of the potmetal bowl for flat across where the bowl gasket is placed. Ours was warped where the 4 screws had been tightened too much. We used a piece of # 50 sandpaper on a flat surface, & ran the bowl across the paper 3 or 4 times. Then take a look to see how many more strokes were needed to bring it to level. Don't be afraid to set the float level more than once to get the fuel level right. We had to go 3 times to get it low enough.
