Re: 300 utility 12 volt wiring harness
Posted by JayWalt on February 07, 2007 at 19:16:40 from (70.226.20.153):
In Reply to: 300 utility 12 volt wiring harness posted by rambler on February 07, 2007 at 18:11:03:
quite easy. There should be a main battery wire to one terminals of the solenoid. then there is one from the harnass that goes on that same terminal, then a smaller one for the "trigger" on the solenoid. not sure what the extra wire is for, but if it has documentation saying it goes there, put it there, they might have just wired the harness slightly different.
