Re: Farmall A Exhuast Manifold torque spec
Posted by glennster on February 09, 2007 at 06:25:46 from (68.78.75.201):
In Reply to: Farmall A Exhuast Manifold torque spec posted by Chad from Michigan on February 09, 2007 at 06:11:33:
i dont know the torque spec, but i did put a manifold on my b. same 113 motor. it has a coarse thread stud that goes into the block, and fine thread on the manifold side. i got a little overzealous with the tightening and pulled one stud out of the block, had to heli coil it. id guess maybe 25-30 lbs. best bet is use a 3/8 drive short handled rachet, snug em up, warm up the engine and re-tighten em. dont kill em, just get em firm. the fine threads generate a lot of torque.
