Oil Plugs - Simple Question
Posted by SuperA-Tx on February 09, 2007 at 10:57:48 from (4.90.53.222):
I been wondering something so Im going to go ahead and ask.
You have the oil plugs on the gear box and on the final drives that are about 1 1/2 inches wide. In the center is the square 1/2 opening where you put the end of the socket to tighten or loosen it. At the bottom of that square hole on the plugs you see on each corner a tab kind of thing sticking out with jagged edges and they meet in the center forming a diamond shape. Then theres a little space between them and the actual bottom of the plug. Was there a reason it was built like that?
