Re: farmall cub snow plow question
Posted by Bigdog on February 09, 2007 at 14:44:31 from (65.185.32.9):
In Reply to: farmall cub snow plow question posted by maplehillfrm,pat on February 08, 2007 at 17:45:41:
I have 54, 54A and L54 blades. I ran the L54 on a standard cub for 2 years. It will work but if it is a tight plow (not worn) it will not want to sit level when you angle the blade. The trailing end will want to ride high. If it's worn as much as most of them are it will work fine. The only problem with using the L54 brackets is that the push arms are always pointed downward.
