Re: Should I?
Posted by nobody on February 09, 2007 at 16:41:34 from (207.7.174.216):
In Reply to: Should I? posted by JayWalt on February 08, 2007 at 20:16:14:
JayWalt; You can remove those broken bolts if you can get to them with a welder, a mig works best. j ust place nut "not me" over the broken bolt. Even if it is broken down into the threads,with wire welder, you can weld up to the nut. Most times it turns right out. I sheared the flywheel bolts of of Cummins engine.Our company welder used this method to take brokem bolts out of the crank,run a tap thru. the threads,new bolts,two days, she was up and running. Welder said ,the reason bolts broke,was they had crystalized. He used 20 nuts 6 bolts in 1/4 lenghs. Did learn one thing,grade 8 bolts didn't last but 3 mos. Ordered bolts from cummins second time.1 1/2 yrs. later shes still running fine Steve
