Re: Difference between Farmall A and B
Posted by Steven@AZ on February 10, 2007 at 06:03:51 from (24.121.155.253):
In Reply to: Difference between Farmall A and B posted by Tree Farmer1414 on February 10, 2007 at 05:50:07:
Farmall A and B have the same engine and transmission. On both tractors you sit to the right side of the engine (IH called it culti-vision). Implements designed for one will not fit the other. On tractors without hydraulics you could have an exhaust lift or simply a manual lift (armstrong).
The A has an axle extenstion only on the right hand side and has a wide front end. The A was not available with a hydraulic system, just an exhaust lift. The Super A added live hydraulics and a horsepower boost to the A. Here is a picture of an A:
third party image
The B has an axle extension on both sides and a narrow front (with two wheels or one wheel). The B was never available with any hydraulic system, just an exhaust lift. Here is a picture of a B:
third party image
third party image
The BN had shorter rear axle extensions by 4 inches on each side, for an overall width 8 inches narrow than the regular B.
The B was replaced by the C which evolved into the Super C - they had axles like the H and M for a greater range of adjustment to tread width.
