Re: Need some chain saw help.
Posted by Chris from Wa on February 10, 2007 at 13:20:33 from (71.212.9.80):
In Reply to: Need some chain saw help. posted by Paul Shuler on February 10, 2007 at 13:08:50:
Pinching the bar? If the cut closes on the bar it can pinch the chain. Also, how tight is the chain? With the saw off and gloves on, you should be able to move the chain easily by hand. If you're using a roller tip make sure it is lubed. If you have a roller tip, there is a small hole in the side of the tip for a grease gun.
