Re: First time Paint job
Posted by glennster on February 10, 2007 at 16:39:51 from (68.60.242.156):
In Reply to: First time Paint job posted by JPM in WA on February 10, 2007 at 00:43:14:
a lot of good advice here. for your first paint job, keep it simple. get the tractor clean, grease and rust free. if you want an inexpensive paint, you can get satisfactort results with the farm and fleet brand in i-h red, its 18-20 gallon, use there primer too. they have a valspar hardener that you can add to the paint. if you can get a spray gun, borrow, rent or buy depending on your budget. if spraying, thin the farm and fleet brand about 10-15 %. sprays better. i think they use mineral spirits, but check the can. to be sure. good luck!!! its a lot of work, but preparation is 90% of a good paint job
