Re: Remote Hydraulics on a 340U
Posted by Wardner on February 10, 2007 at 21:33:50 from (206.148.20.4):
In Reply to: Re: Remote Hydraulics on a 340U posted by PaulW_NJ on February 10, 2007 at 19:13:36:
"That is, would I have to hold that HydroTouch valve down to send pressure to the remote output, or would it always be “hot”" You could use a bungy cord. What do you get for $400? Would that be the 10gpm or the 20gpm? I would get the 20gpm but I think they cost more than $400. You have other options, I think. Don't utilities have a bolster that allow for the mounting of a pump in line with the crankshaft pulley. Some tractors have a crankshaft pulley with four bolts threads for mounting a splinded flange that accepts a short driveshaft. The other end goes into a pump that attaches to the front of the bolster with two or four bolts. The driveshaft passes through the crank hole. The pump can be physically smaller (and cheaper) because it turns four times faster. You might also locate a "step-up" PTO gear box similar to what is used on PTO generators. Some generators turn 1800 but most whip around at 3600rpm. A pump attached to the output of the gear box would be small and cheap. A high hydraulic flow to your splitter means you can run your tractor engine at a slow speed. I run my 20gpm pto Prince pump, that pushes a 4" cylinder, at 900 engine rpms. "If you OVER build it, you will ----". Sorry, that was disgusting.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
