Re: cab door for 886
Posted by El Toro on February 12, 2007 at 07:24:40 from (64.12.116.71):
In Reply to: cab door for 886 posted by reeb on February 12, 2007 at 06:15:10:
If you know what company that made the cab I would try and contact them to see if a kit is available. Your local Case'IH dealer may know if a kit is available. Hal
