Re: Got the 300u going, but...
Posted by Nat 2 on February 12, 2007 at 07:25:38 from (64.80.110.27):
In Reply to: Got the 300u going, but... posted by JayWalt on February 11, 2007 at 19:30:32:
As far as I know, IH tractors use what is called an "open center" system, which means that when all the remotes are centered, the system is open straight from the pump to the reservoir.
It is my understanding that the safety regulator (i.e. relief valve) has nothing to do with directing flow to the reservoir when the remotes are not being used. The relief valve activates when the pump is deadheaded, and dumps the excess pressure off to the reservoir.
Does your tractor have power steering? If so, it has a priority valve that directs flow to the power steering when it demands pressure. That may be where your problem is.
