Re: Got the 300u going, but...
Posted by Bob M on February 12, 2007 at 07:53:20 from (151.190.254.108):
In Reply to: Got the 300u going, but... posted by JayWalt on February 11, 2007 at 19:30:32:
Jay - I’m not familiar with the 300U hydraulic system in particular. However it works basically the same as the live hydraulics on the Super series Farmalls – and I am quite familiar with those. ---- Anyway it sounds as if your hydraulics are somehow plumbed incorrectly. Your 300U has what’s called an “open center” hydraulic system. When no hydraulic action is required oil flows from the pump to the control valve, passes freely through the control valve and then returns directly to the reservoir. No pressure is developed and the pump runs unloaded. Now when you move a control valve to extend or retract a cylinder, the control valve redirects flow from the pump to one side of the cylinder and at the same time directs return flow from the opposite end of the cylinder back to the reservoir. The amount of pressure developed at the pump now depends upon the load on the cylinder – the greater the load the higher the pressure. The relief (or safety) valve is located in the line between the pump and the control valve inlet and monitors pressure in the supply line. It should open ONLY when it’s set pressure is exceeded – for example when the cylinder reaches the stop at end of it’s travel and the control valve is not released, or if the cylinder is overloaded. Otherwise the relief valve should never operate. (Incidentally when the relief valve operates it develops a tremendous amount of heat. If left to bypass for very long it’ll cause the hydraulic system to overheat….) Consequently your relief valve opening with the control valve in “neutral” says your plumbing is somehow messed up. Also if your tractor has power steering the flow divider that supplies the steering system may not be working and is constantly restricting pump flow. ----
The pulsing of relief valve could be from several causes: The oil level may be too low (pump is sucking air). Could also be an excessive suction side restriction - collapsed suction hose, clogged screen/filter, filter too small for the pump flow. Finally it could be be incorrect (too heavy) oil the system. Hope this helps, and good luck!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
