Re: M - Big Bad Brake Seal
Posted by Michael Soldan on February 12, 2007 at 12:43:02 from (24.235.41.226):
In Reply to: M - Big Bad Brake Seal posted by PatMz on February 12, 2007 at 12:23:45:
Pat there are a few ways. Some drill little holes in the steel side of the seal and put metal screws in , then you can get a vise grip on and pull. I have good luck with small chisels and punches...get between the tractor casting and the seal with a tiny sharp punch , keep working it intil you begin to collapse the steel shell, knocking it out of round and collapsing it toward its centre point, once you have knocked the seal out of perfect round it loses its integrity and will pull out easily with a vise grip. remember the bearing is directly behind the seal so don't go postal on the chisel or punch..good luck, it sometimes takes a little while
