Re: Re: Re: Super M soup up
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Nick on February 07, 2000 at 16:46:17 from (63.14.253.229):
In Reply to: Re: Re: Super M soup up posted by 100Glenn on February 07, 2000 at 09:36:31:
Well once every year you have to put in axel bearings but that is more from the weight (7500-8500 lbs) Other wise we use a 1456 springs on the preasure plate and a aircraft type of material on the face. The old trannys will old up real good. We have not busted any thing major yet but I am sure with time it will. Another way of Cheap powere is to find a 450 manifold with the 3 castings holding the intake & exh. together grind those off and you'll have less heat exchange and cooler air going in. Best of luck
Nick
Post A Followup
: Re: Re: Re: Re: Super M soup up
