Re: 1256 alternator wiring
Posted by K.B.-826 on February 12, 2007 at 19:43:13 from (71.10.83.51):
In Reply to: 1256 alternator wiring posted by Brian in AR on February 12, 2007 at 18:32:22:
There should be a very heavy wire with a ring terminal. That one connects to the + post of the alternator. There should also be a grey square plug with two wires going into it. This plugs into the back of the alternator. Case-IH still has new harnesses avalible for these tractors. I'd really recommend rewiring yours if the wiring is in tough shape. I've got brand new wiring on four of our seven tractors now, gonna do the fifth one when it warms up, one I can't get harnesses for, and one doesn't need it. Sure is nice when all of the lights work and you don't have to worry about a bare wire touching ground and burning up the tractor. Your Case-IH dealer's shop probably has the old manual with wiring diagrams for everything up to the 06 series. Ask them if they will make you a photocopy of the diagram for a 806 Diesel w/ alternator or a 1206. Those will be almost identical to your 1256.
