3514 Backhoe
Posted by adefreit on February 13, 2007 at 12:10:02 from (205.167.6.1):
I have the opportunity to purchase this unit. It through a rod through the block. It has a hydrostatic transmission. I am going to look at it over the weekend.
Can anyone tell me how to identify a D-188 versus a D-239? Where is the serial number located? Also, what should I look at on the hydrostatic transmission?
Thank you for your help.
