Clutch Torque Specs
Posted by Tyler Cohrs on February 13, 2007 at 17:48:15 from (198.70.5.111):
I'm putting the Clutch components together on my 1950 WD6 and would like to know the Torque Specs for everything. Mainly the Flywheel, Preasure Plate, and the four bolts on the clutch coupling shaft. Thanks for your help!!
