Re: Farmall C start
Posted by old on February 13, 2007 at 18:37:13 from (4.245.14.239):
In Reply to: Farmall C start posted by Dave_Id on February 13, 2007 at 18:23:57:
Only way it will start and run is if it has a mag type ignition system on it. If it has a distubutor on it then you need a good battery or it will not have spark and of course no spark means no run
