Re: Farmall C start
Posted by CNKS on February 13, 2007 at 19:07:22 from (204.249.178.32):
In Reply to: Farmall C start posted by Dave_Id on February 13, 2007 at 18:23:57:
It has to have some charge. You can hand crank start a battery ignition tractor with an almost dead battery. If the starter turns it over very slowly, it often will not start because the drain caused by the battery does not leave enough spark at the plugs to get it running. Hand crank it and the remaining charge goes to the plugs. If it has been sitting a long time the battery is toast. Why don't you just buy a new battery?
