Re: 1954 Super H diesel
Posted by D Slater on February 13, 2007 at 20:09:20 from (205.188.116.133):
In Reply to: 1954 Super H diesel posted by SonnyDey on February 13, 2007 at 18:53:01:
The 350 D engine used a injection pump on left side mounted in a partly vertical position. If the rearward housings have a Z on them there either a last year SH or a early 300. SH housings serial # plate located on left side of tractor. 300 serial plate postion on right side. Those could be modified though,also someone that went to trouble to build tractor like that with the know how could change the date code letters. Where the center housing bolts to transmission if you can only see one bolt at top on both sides its H or SH rear. If starter is closer to right side of tractor it doesn't match a Z code housing unless a replacement. How about a picture, I'm not sure you are not pulling our leg. Apology given if I'm wrong.
