Re: Farmall B - Lift Cylinder, etc.
Posted by 1941 framall a boy on February 13, 2007 at 22:52:00 from (216.98.171.8):
In Reply to: Farmall B - Lift Cylinder, etc. posted by AgE94 on February 13, 2007 at 20:26:24:
Hi i have a 1941 farmall "a" im restoring and it has the same thing and it is call'd an exhaust lift if you get on www.ebay.com and type in farmall "a" thay have some stuff for the exhaust lift that will fit on the "b".
