Re: 560 wont start
Posted by El Toro on February 14, 2007 at 02:46:50 from (64.12.116.71):
In Reply to: 560 wont start posted by dhinton@ccrtc.com on February 13, 2007 at 20:15:14:
You need to make sure you have voltage at the coil. With the ignition switch in the on position you should have voltage on bothe small terminals on the coil. Use a test lite or volt meter set on DC voltage 15-20 scale. The points need to be open too. If there's no voltage present at the coil you need to check back at the switch to see if voltage is on the terminal that feeds voltage to your coil. These ignition switches are usually fed voltage from small terminal on the starter solenoid. Its usually close to the large battery cable on the solenoid. If there's no voltage from the switch to the coil you need to check for voltage from the solenoid to the switch. Run a temporary wire from your battery to the coil and see if the tractor will start. Clean those points with a piece of 320 wet or dry and clean those points and then take a cotton swab dipped in alcohol and clean the points. If you have a good condenser install it. Then pull that coil wire from the cap and hold it within 1/8-1/4" of a good ground while someone cranks the engine. Hal
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
