Re: 153 engine
Posted by Wardner on February 14, 2007 at 08:26:14 from (206.148.20.156):
In Reply to: Re: 153 engine posted by steelfronts on February 14, 2007 at 07:27:00:
I only know about the stuff that I own. I don't kbow about A's,B's, or C's but I do have a 153 cubic inch 504. The back of the motor (flange that bolts to clutch housing) is cast integrally with the block; kinda like a Cub. It should bolt up to the center section of a H, 300, 330, 340, 460 and maybe others. As for starter, flywheel, and clutch, I suspect some combination of parts and a little machine work would get the job done.
