Re: Cylinder Sleeves
Posted by Janicholson on February 14, 2007 at 16:52:13 from (66.173.50.66):
In Reply to: Cylinder Sleeves posted by Dave From Texas on February 14, 2007 at 10:31:58:
Dear Dave, the information so far has "kinda" missed what I said in my post below, these are wet sleeve engines. the sleeves are modestly easy to remove and in no case require welding or a puller. Many of these come out when the crank is rotated, and the pistons move up on somewhat rusty cylinder walls. In many cases they will come out when the rods are disconnected, and the piston is pushed up from the bottom. If the pistons are out, put the wood I mentioned against the bottom of the sleeve and rap it with a mallet. They come out! The best option would be to put the largest cylinder bore/piston kit in it (you will be replacing the entire cylinder with ones that are slightly thinner, and putting in new pistons, creating a 123 cid engine where a 113 was before. (unless it was already maxed out) Kits from this site are good. The crank would only be usable as is ====only==== if just the lightest surface rust was on it. If 000 steel wool and just two passes remove the rust, and if it mics out (across the journals, and around the journals at least 6 to 8 locations per journal) would I leave it in the tractor. To remove it requires the splitting of the tractor it is necessary, not optional. JimN
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
