Re: 424 problem
Posted by Bob on February 14, 2007 at 19:37:14 from (69.178.229.154):
In Reply to: 424 problem posted by ler on February 14, 2007 at 17:51:56:
If this is the 3/4" plug at the RH rear, near the RH rockshaft lever, it isn't REAR END oil.
It's HYDRAULIC SYSTEM oil. The hydraulic reservoir/rockshaft housing sits on top of the rear end, and it's oil is SEPARATE of the rear end/transmission oil.
Are you losing ENGINE oil, and "gaining" hydraulic oil? If so, either the engine timing gear driven oil pump has a bad seal, and is taking in engine oil, or you may have a leak in the pump seal or suction piping that is taking in AIR, and "foaming" the oil.
Also, if the 3-point control valve is not set up right, or the auxillary implement valve (if used) is not returning to center, the pump will always be working against the relief valve, heating up the hydraulic oil.
Does the hydraulic system continuously "hum" or "buzz", like it's the relief valve is operating continuously?
