Re: C-113 crank pulley
Posted by El Toro on February 15, 2007 at 03:37:31 from (64.12.116.71):
In Reply to: C-113 crank pulley posted by thumbanger on February 14, 2007 at 15:05:30:
Make sure the hub on the damper pulley doesn't have a groove worn into the metal from the old seal. If it does use a speedi seal to cover the area. 300 degrees should be enough heat. Hal
