B rearend
Posted by mpriar on February 15, 2007 at 09:18:38 from (165.139.184.240):
I have some noise in the rear of my B. This tractor has been sitting for quite awhile with water in the transmission. Is there one certain bearing that is most likely the problem, or do I have to start replacing all of them? Not a grinding noise but more like a roar/whine. Or could there be another problem. I have drained the trans. Should I clean with Kerosene before I put in new fluid? What about the final drives? Take the pans off and drain/clean?
Thanks
